Browse Forums Outdoor Living 1 Apr 13, 2012 1:46 pm I am considering putting an 32" LCD screen in my outdoor entertaining area. It is under cover but I want to find the best option for making sure it is protected from the elements. Was thinking about making an acrylic box to house it in, but wondered if anyone had any suggestions on how this could be done? Ideally it would be on a swinging/rotating wall mount as well but that part is not critical. Re: TV in outdoor entertaining area 2Apr 13, 2012 2:48 pm Just put a plastic cover over it when not in use like they use to have for computer monitors and keyboards. http://lindeman28.blogspot.com - Our building blog Re: TV in outdoor entertaining area 3Apr 16, 2012 11:21 am You can place a cover over it when not in use, but I would think carefully about a permanently fixed perspex box for it! Wouldn't want the TV to stay lovely and dry only to overheat! Maybe you could make up / get a perspex cover that can hook over the top when not in use? Or possibly you could build the TV into a cabinet on the wall? Would have the added bonus of hiding the TV from sight! Re: TV in outdoor entertaining area 4Apr 18, 2012 1:32 pm Depending on your budget you can buy a TV designed for out door check for sites like these http://www.innovizion.com.au/?gclid=CKW ... pgodMDFaxA Re: TV in outdoor entertaining area 5May 11, 2012 9:47 pm I've done the same, 32" LED setup in the corner of the alfresco. I have put it on a wall bracket that allows the tv to be easily removed. So when I know I won't be out there or a while, I remove it. The tv is light weight nd bracket makes it easy, so no problem. Re: TV in outdoor entertaining area 6Jun 03, 2012 10:39 pm I'd thought about doing this and using a dart board box or something similar and just putting rubber sealing strips on the doors and sealing the rest of it for when it's not in use (and its also hidden from prying eyes) and then just open the doors up when you want it on show. Haven't actually got around to trying it yet though. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17647 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 30105 Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to… 0 28198 |
