in the process of about to stain my new blackbutt decking.
before staining is it best to give it a scrub down and then a light sand or just stain directly. There are some slightly work boot marks on the boarding.
cheers
Browse Forums Outdoor Living 1 Oct 05, 2010 2:02 pm in the process of about to stain my new blackbutt decking. before staining is it best to give it a scrub down and then a light sand or just stain directly. There are some slightly work boot marks on the boarding. cheers Williams Landing Stage 2 - Building Nolan with Big M - Slab Poured 09/11/09 Frame started 17/11/09 Brick started 05/01/10 Lock-up 31/01/10 Re: Blackbutt decking 2Oct 05, 2010 9:41 pm wash it down let it dry then apply stain I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Blackbutt decking 3Oct 06, 2010 9:18 am All you need to know and some more can be found here http://www.*.com/f196/clean ... eck-75429/ Regards PP Re: Blackbutt decking 5Oct 07, 2010 5:12 pm use a specific deck clean ie: cabbots deck clean, follow instructions to the 't' then rinse off. If you use a pressure cleaner make sure you clean every single square inch with the same spray pattern or you will leave lines in the surface of the deck timber. I usually use a pressure cleaner on a fan pattern and at a distance purly to lightly clean the surface not damage it with water pressure. Let it thouroughly dry before sealing, Sikkens is a top quality sealer, use an oil not laquer or varnish Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Blackbutt decking 6Oct 08, 2010 1:40 pm davinci use a specific deck clean ie: cabbots deck clean, follow instructions to the 't' then rinse off. If you use a pressure cleaner make sure you clean every single square inch with the same spray pattern or you will leave lines in the surface of the deck timber. I usually use a pressure cleaner on a fan pattern and at a distance purly to lightly clean the surface not damage it with water pressure. Let it thouroughly dry before sealing, Sikkens is a top quality sealer, use an oil not laquer or varnish thanks - busy weekend ahead Williams Landing Stage 2 - Building Nolan with Big M - Slab Poured 09/11/09 Frame started 17/11/09 Brick started 05/01/10 Lock-up 31/01/10 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10970 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15764 Hi, Really struggling to find some consistency amongst Span Tables, can anyone help… 0 2655 |
