Browse Forums Outdoor Living 1 Jun 20, 2023 3:24 pm I recently had my pergola done by a company. Its 5.5 meters long and 6 meters wide. The posts are 150×150 mm and 2mm wall thick aluminum material. Fascia brackets are spray painted with spray can (not primed before spraying). Beams are bit short, not grooved full into brackets. Missing some screws on beams. I was wondering 1) would beams of 2mm thickness support load of this pergola? 2) can spray paint last long than powder coated 3) Missing screws normal? 4) beams coming out from brackets poor workmanship or problem? 5) Would also like to know if any other problems that you can spot here. Sorry for too many questions. Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New Pergola 2Jun 21, 2023 1:23 pm Is there a building permit? RU in Victoria? What is the value of the building contract? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29808 i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple… 2 8478 |
