Browse Forums Outdoor Living 1 May 21, 2023 12:41 pm Hi All Our backyard colourbond fence located on a busy road and it wobbles when cars drive pass it and when it is windy as well. It's colourbond and with 8 posts concreted in but the whole length of fence (7 panels x 2.3 = 16m) does like a wave as the wind hits it. I bought two star pickets 2400mm similar to those ,,,temporarily support https://australianhardwoodstakeco.com.a ... r-pickets/ The fence is screwed to a timber boards on ground as can be seen on the attached pictures and they rotted How can I brace it properly to avoid its falling ? Thx Although have uploaded photos I can't see them ,,,,,I have attached a link to the photos as well https://imgur.com/a/oqXhnmN Re: How to brace a colourbond fence that wobbles 2May 22, 2023 6:48 am Any bracing would be temporary in nature.
Adding a diagonal (nominally 45-75-ish degrees) support from the ground to somewhere along the top third of each post will certainly stiffen it up. Screw the top end directly into the post with some self tapping sheet metal screws. I would also add some stakes at the ground end of each support roughly perpendicular to the angled support and screw through these into that angle support so that they are fixed to the ground. what this chap is doing in this video from 1:10-1:30min section. Re: How to brace a colourbond fence that wobbles 4May 22, 2023 9:52 am The first thing you want to do is check how large the concrete blocks are that were poured around each post. Some fence contractors skimp on the concrete and the fence doesn't have a lot of strength. You may be able to add extra concrete at strategic places if it's lacking Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 9107 Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like… 0 7521 1 4604 |
