Browse Forums Outdoor Living 1 Apr 06, 2023 1:03 pm Hello, I'm in the process of having this firepit built and before using it, I wanted to get some opinions on the safety of it. It has a brick base with concrete above and a firepit bowl directly on top of the concrete. Do I need to be concerned about the concrete overheating and exploding? Thank you! Re: Firepit - concrete with metal bowl 3Apr 06, 2023 3:52 pm You'll be fine. If you are using a phone click reply to your own post and then you have the option to add photos Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Firepit - concrete with metal bowl 4Apr 06, 2023 4:16 pm MaxD29 Hello, I'm in the process of having this firepit built and before using it, I wanted to get some opinions on the safety of it. It has a brick base with concrete above and a firepit bowl directly on top of the concrete. Do I need to be concerned about the concrete overheating and exploding? Thank you! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Firepit - concrete with metal bowl 6Apr 06, 2023 4:58 pm You are fine. The concrete is never going to explode. Worse case scenario is that it develops a crack from different rates of expansion but hopefully it's got some reinforcement in it so even a crack won't be a problem Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5534 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 11038 |
