Browse Forums Outdoor Living 1 Aug 13, 2022 6:03 pm Hi, Looking to put a roof over the side area of our home The area is about 7mx3m and is a combination of conrete pathway and decking The lot next door is vacant and a designated road (owned by council) when the estate expands, when buying my block it is designated as a corner lot Our lot is also higher than the one next door and retaining and fencing is in place We are getting quotes for a roof and are getting mixed advise from the builders of these things - Some say i have to be 900 off the fence (which makes the roof pointless to install) - Others say as its a corner lot and much higher than the other then a roof with a couple of posts inside the fenceline is fine ++ the roof is 3m off the path level so plenty high - others say just build it and dont worry as its inside the m2 for approvals anyway we are so confused now Should i first get an engineer or private certifier out? Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8842 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20269 DIY, Home Maintenance & Repair Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which… 2 12916 |
