Browse Forums Outdoor Living 1 May 04, 2022 5:43 pm HI I am Melbourne based We plan to install a bbq bench and rangehood ( the pergola area here will eventually be enclosed so smoke will be a big problem) The problem is as you can see in the photos is that directly above the brick wall there is 2 gutters ( one joined to the house and one joined to the pergola ceiling There is also a support column there but we can just move the rangehood more to the right The duct would either have to go through the brick wall and up to the house ceiling cavity or up and then come forward and go through the pergola ceiling If anyone has any ideas on how to not make it look degusting or if anyone has anyone they can recommended to install or give advice please share THanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How would I install an alfresco Rangehood here? 2May 06, 2022 9:46 am Go through the house wall and then up out though the roof. Alternately depending on what the pergola roof is made of the external fans may be able to be mounted on it but you may also get a lot of transmitted vibration/noise. That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8691 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4239 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4977 |
