Browse Forums Outdoor Living 1 Jan 14, 2022 1:08 pm Hi I live in Shire of Melton Council. I have a verandah built without the permit and council building surveyor says it need to be regulated. One of the problems that was identified was that it is close to the side boundary fence in as much as 250mm . He said that a minimum o 500 mm set back is required for Verandah to be compliant. I was looking for Guidelines to build the Verandah but could not find anywhere. Any member has a copy of the guidelines to build Verandah and minimum setbacks to be left etc and is kind enough to share will be highly appreciated.. Cheers Ajay Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3500 1 3177 Adam Baines Grad Cert Bldg Surv / Grad Dip Bldg Surv / MSAAPA Accredited Building Professional APB20210035 Builders Lic 183023 Pest Control Lic 84868 Ph 0412202336 PO… 3 47196 |
