Browse Forums Outdoor Living 1 Apr 24, 2021 3:13 pm We are fully enclosing our pergola and installing a kitchen with built-in bbq. The walls will be cladded with a product by James Hardie and ceiling will be plastered using blue board. No insulation. We will have windows and a sliding door. Barring any leaks, the kitchen will be protected from the elements. My question is can I use a Laminex bench top? Many people suggest granite or ss however this will be completely undercover. Thoughts please. Re: Laminex bench top 2Apr 24, 2021 8:11 pm If it's never going to get direct rain you should be fine. Ask for the benchtop to be made on aquaban blanks. The underside of those boards are coated in melamine so it helps protect both sides of the board from high humidity. Personally I always build with waterproof materials in alfresco settings just because I feel it's best practice, but I've seen plenty of standard internal style kitchens installed in alfresco areas that have lasted well. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Laminex bench top 3Apr 25, 2021 7:08 am chippy If it's never going to get direct rain you should be fine. Ask for the benchtop to be made on aquaban blanks. The underside of those boards are coated in melamine so it helps protect both sides of the board from high humidity. Personally I always build with waterproof materials in alfresco settings just because I feel it's best practice, but I've seen plenty of standard internal style kitchens installed in alfresco areas that have lasted well. What do you mean by aquaban blanks? I looked up the meaning and nothing came up. Re: Laminex bench top 4Apr 25, 2021 10:37 am Post formed laminate benchtops are often pressed onto raw MR particle board blanks which means the underside is just a raw particle board finish. That's fine for a kitchen but aquaban blanks have one side with a melamine finish. This goes on the underside so you have laminate on the top and melamine on the underside. It just means the whole board has a coating and will help with humidity. Some postformers use them all the time some just use raw blanks. I'd just specify it to make sure. Here is the link. https://www.laminex.com.au/products/aqu ... /AU1000055 Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Laminex bench top 5Apr 25, 2021 8:49 pm chippy Post formed laminate benchtops are often pressed onto raw MR particle board blanks which means the underside is just a raw particle board finish. That's fine for a kitchen but aquaban blanks have one side with a melamine finish. This goes on the underside so you have laminate on the top and melamine on the underside. It just means the whole board has a coating and will help with humidity. Some postformers use them all the time some just use raw blanks. I'd just specify it to make sure. Here is the link. https://www.laminex.com.au/products/aqu ... /AU1000055 Great advice. Thanks mate. Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31642 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 4079 Caesarstone, quantum zero, Q Stone zero, porcelain. All the manufacturers are pivoting into zero silica materials. Google any of those and have a look. Some are still… 1 1639 |
