Browse Forums Outdoor Living 1 Jan 25, 2021 1:44 pm Hi. Newby here. I need some advise on a shed I'm going to build. Its a 4800 x 2800 x 2500ish flat roof ( slight fall ). Firstly I'm after some advise on timber sizes for the stud walls? its going down on a slab. What size studding? I was going for 90 x 35? Also do I bolt the bottom plate straight onto the slab or use a moisture resistant timber first or wrap some waterproofing around it? 2 x top plates? What size centres for the studding? Thanks in advance. DCM. Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5910 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3747 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 6262 |
