Browse Forums Outdoor Living Re: Staining a treated pine deck..... 22Mar 13, 2008 5:03 pm zaff Here a couple of pics when I was building our deck. It's made out of ash which has a light pine kinda colour. It now has two coats of British Jarrah stain. But I may go darker, maybe a coat of merbu coloured stain on top. Still needs an oil Why not just use merbau in the first place?? Re: Staining a treated pine deck..... 23Mar 14, 2008 8:42 am I needed about 1000l/m and I got this lot for a little over $1l/m. Best I saw Merbau was about $3.50l/m. I was more concerned about building a quality subfloor.
I figured the $2500 could be better spent elsewhere. Re: Staining a treated pine deck..... 24Mar 14, 2008 5:03 pm After all that time and money spent staining it, don't waste it by using a cheap decking oil which will last 6 months. Use a a product like Sikkens ( which you can get already tinted, could have saved you a lot of time) Hi, I have an area of zincalume cladding encasing a number of external downpipes. Unfortunately one of them has been permanently stained by some diluted phosphoric acid -… 0 1061 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 7332 I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 53106 |
