Browse Forums Kitchen Corner 1 Apr 06, 2020 1:17 pm I have a induction cooktop and my sparky installed the hob switch together with couple of light switches, as a result a 4 gang switch with 3 switches controlling the light and 1 use as the hob switch. (The induction cooktop has a dedicated line from switchboard to the cooktop, it also has a switch on the switchboard) I would like to install a smart switch to control the light, so can a touch switch to be used as isolation / hob switch? Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1900 Hello I'm remodeling my kitchen and evaluating ideas. We are in the last stages of drawing and I am now considering putting a pot filler tap in above the hob. Has anyone… 0 1500 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3313 |
