Browse Forums Kitchen Corner 1 Sep 25, 2008 10:53 pm Hi guys!
Has anyone happened to have come across kitchen cabinetry with a silhouette or pattern in them?? Kind of similar to having patterned tiles as a feature on bathroom walls..? Does that make sense at all?? Been trying to think of a way to make the kitchen cabinetry a 'feature' without just having a bright colour! Any thoughts/ideas/suggestions would be great!! Thanks!! Adam Re: Kitchen cabinets with a silhouette/pattern?? 2Sep 26, 2008 9:07 am Hi Adam, have a look at this website through laminex, it might be able to help.
http://www.fusionsurfaces.com/mod_home/home.asp Re: Kitchen cabinets with a silhouette/pattern?? 3Sep 26, 2008 6:34 pm gweluphome Hi Adam, have a look at this website through laminex, it might be able to help. http://www.fusionsurfaces.com/mod_home/home.asp Thanks PK! Looks pretty much exactly what I'm after! Now just have to convince everyone else that it could look amazing!! Generally, the texture that you listed will have a 2mm size stone chip in it which is dragged with float to give the lines Any patch work needs to be 2mm less than face… 2 1913 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10692 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 41453 |
