Browse Forums Kitchen Corner 1 Dec 18, 2019 8:57 pm I am working with my cabinet maker in trying to work out the most ideal size for a window for our walk in pantry. We have a 2700mm ceiling height and with an 1100mm tall overhead means we have an opening of around 680mm for the window. Does anybody have a similar height splashback that they can show some photos of what this looks like? I'm concerned that it will be too tall. The alternative is to get a 600mm window and just plaster above the window (so the overhead wouldn't butt against the window), but I think this might look worse than a taller window. Re: Is 700mm too tall for a splashback window? 2Dec 24, 2019 10:41 am We don’t have a window splashback, but we have 740mm between bench and overheads and I don’t think it looks odd. We do have a bulkhead above the uppers as we also have 2.7m ceilings and this brings the top of the overheads to 2.39m to match the top of the internal doors (900mm bench height, 740mm splashback, 750mm overheads). As we are having an induction cooktop the rangehood (undermount) is recommended to be 700-750mm above the cooktop. If it were me, I’d have the window the entire height - frame to bench and frame to underneath overheads). Bear in mind that the window size is not the glass size either, so a 700mm window will include the frame. Second Time 'Round Re: Is 700mm too tall for a splashback window? 5Dec 24, 2019 12:29 pm Thanks for the replies guys! I ordered the 740 window in the end so that the overheads will butt into the window head and the stone will flow into the window. Thanks for the images, very helpful! Re: Is 700mm too tall for a splashback window? 6Jan 28, 2020 1:03 pm arcadelt Hi arcadelt, can i ask what is the length of space you have on either side of your cooktop? Re: Is 700mm too tall for a splashback window? 8Jan 30, 2020 6:33 pm lockmac I am working with my cabinet maker in trying to work out the most ideal size for a window for our walk in pantry. We have a 2700mm ceiling height and with an 1100mm tall overhead means we have an opening of around 680mm for the window. Does anybody have a similar height splashback that they can show some photos of what this looks like? I'm concerned that it will be too tall. The alternative is to get a 600mm window and just plaster above the window (so the overhead wouldn't butt against the window), but I think this might look worse than a taller window. 700 high is perfect. by chance i was visiting display homes the other day and came across one that was perfect. this measured approx 720mm If you're in a flood zone, not only are you dealing with the importation of fill and laying it down in 150 lifts to achieve compaction, you're going to have to consider… 4 5736 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8543 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5794 |
