Browse Forums Kitchen Corner 1 Jul 23, 2016 6:33 am Building a house at the moment and thinking of getting a Whispair Monte Carlo 2010 m3/hr rangehood (http://www.whispair.com.au/#!monte-carl ... 09s3/c15fe) and a Highland 98.5cm 6 burners gas cooktop (http://media.wix.com/ugd/d71382_ab9ec03 ... 1cc7e0.pdf). The reason for picking the 300mm deep rangehood is to give the kitchen a seamless look. I do do some heavy cookings at times. Im wondering if the 300mm deep undermount rangehood is sufficient to extract smokes and odours, given the cooktop is much deeper and slightly wider than the rangehood. Can anyone with a standard depth (300mm) undermount rangehood with a standard depth (600mm) cooktop comment on this? Will it work? Thanks. Re: Is a standard depth (300mm) undermount rangehood enough? 2Jul 25, 2016 8:30 am Persimmon Can anyone with a standard depth (300mm) undermount rangehood with a standard depth (600mm) cooktop comment on this? Will it work? Thanks. The vast majority of kitchens these days have exactly what you are talking about. I have it in my home and don't have an issue. You just need to make sure you have a rangehood with decent extraction. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 6255 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27808 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5963 |
