Browse Forums Kitchen Corner 1 Nov 24, 2015 8:20 am Due to budget constraints, we can't replace the whole kitchen yet. Planning on just replacing the stove and oven. However, the old stove and oven are 600 mm ones and are side by side and on top of the kitchen counter assembly( dips about 500 mm from bench top, pretty unusual). We will be replacing them with a free standing 900 mm stove/oven. Questions are: Do i need to have a plumber and electrician to disconnect and remove the old stove and oven or can i just do it myself? . Re: Replacing old gas stove and oven with 900 mm free standi 2Nov 24, 2015 10:02 am Doing kitchen renos for a living, I used to disconnect gas and electric stoves all the time. As long as you turn the power supply off and disconnect the wiring and use plastic connectors for each cable to terminate them then wrap them with some electrical tape you should be fine. With the gas there should be a gas on-off valve below the stove. Just turn that off and disconnect the stove. When you install the new one however all the reconnecting should be done by the sparky and or plumber. Stewie Re: Replacing old gas stove and oven with 900 mm free standi 4Nov 25, 2015 9:36 pm As a plumber and gas fitter with restricted elec license to things i tell all my customers dont play with gas an electrical as you cant see both and both can kill you. Your call your duty of care Hi, we live in an area where the black soil is prone to a lot of movement. We have an old 50's house with masonite everywhere and nails popping out, warping, rusted etc.… 0 4761 Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2520 Yes, get a builder, make sure he is experienced and a registered building practitioner 5 9321 |
