Browse Forums Kitchen Corner 1 Jan 13, 2014 1:21 am Hi there, I am a first time renovator. I need help with my kitchen design, and suggestions appreciated. [img][IMG]http://i1069.photobucket.com/albums/u476/mr63249/Kitcheddoorsclosed.jpg[/img][/img] [img][IMG]http://i1069.photobucket.com/albums/u476/mr63249/Kitchendoorsopen.jpg[/img][/img] [img][IMG]http://i1069.photobucket.com/albums/u476/mr63249/NewImageIslandBench.jpg[/img][/img] [img][IMG]http://i1069.photobucket.com/albums/u476/mr63249/BlackKitchen.jpg[/img][/img] Re: Proposed kitchen design 2Jan 13, 2014 1:25 am The sink will be home to a 4 way faucet. Hot,Cold,Chilled/filtered, Chilled carbonated. Also thinking of introducing a special push activated door to the left side of window which will be home to toaster kettle etc that way it can be easily pushed back into cupboard. Trying to get rid of clutter. Re: Proposed kitchen design 4Jan 13, 2014 10:51 am d@n The layout looks a bit odd and the sink boxed in with not much bench space around it. I found that they recommend 300mm one side and 900mm other side of bench space next to sink so I thought 627mm either side would be sufficient. What is your suggestion? Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 9891 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 19015 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19786 |
