Browse Forums Kitchen Corner 1 Oct 05, 2013 7:10 pm Ugh. I'm trying to configure the space for best use of the space. Extending would see us overcapitalise. We're 2.4m wide. About 4m long. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The wall where the wash tub and washing machine is currently is 1.63m and 63cm deep. The cavity where the freezer is 96cm wide and 76cm deep. The measurements are "about" because the entire lining has to be removed and new plaster put on. The original plan WAS: Sink to stay where it is, and a bench put along that wall with drawers and dishwasher. Where the microwave and fridge are currently, put a bench along that wall with overheads and a cooktop and oven in the middle and undermount the microwave under the overheads. Now the issue with the original plan is the laundry. I want to fit the machine, a side by side fridge and a pantry. The idea WAS to put the pantry where the freezer is, put the washing machine where the tub is and remove the tub altogether and put a side by side fridge where the machine is. The machine is 600mm wide. Which leaves 1000mm for a fridge. But the space is only 630mm deep. Is that enough depth for a fridge? Now I'm wondering if I should put the pantry where the washtubs are, put the machine in the corner and put the side by side fridge freezer where the freezer is currently. If I put the washing machine right next to the back door there is a fear I could end up with the backdoor rammed into me while I'm unloading the machine. Please, give me ideas and thoughts. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10310 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3666 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 7663 |
