Browse Forums Kitchen Corner 1 Apr 28, 2012 9:07 pm hi all we have a quote for an island bench to be installed for our kitchen 3metre long, with 30cm overhang. 40mm thick: 4k. 20mm is about 2.2k Sound about right? cheers Re: price check on a quantum quartz bench 2Apr 28, 2012 10:19 pm Not enough information there.... Quantum Quartz colour? Edge profile: 40mm but Square, Pencil, bullnose??? Island bench size (eg: 3000X900 I'm assuming) is this all, waterfall panels, additional benches?? Re: price check on a quantum quartz bench 3Apr 28, 2012 11:29 pm pencil edge yes the standard 3000X900 nothing else color from the standard range edit: Ouch just found on a website 1100+200 delivery for 1 slab full size. they will polish and cut for you as well... Re: price check on a quantum quartz bench 5Apr 29, 2012 2:24 pm I would have said it sounds a little expensive. I depends if they are returning the double thickness the full 300mm overhang??? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: price check on a quantum quartz bench 6Apr 29, 2012 3:23 pm yeah sounds abit expensive to me... the lady did say where ever it overhangs it looks like its 40mm but the part that is the bench over the cupboard it will be 20mm Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 12438 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31736 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 4225 |
