Hi We have recently moved into our new house and found that the oven timer doesn't make any sound. It counts down and on completion the oven (heat/light and fan) flick off. But no sound. I expect there should be a 'ding' or a beep when the timer finishes to alert you.
Does anyone else have the Westinghouse 900mm built in oven - model number POH967S/1
If so - can you please tell me if the timer makes a sound?
I called westinghouse and they advised that the oven doesn't have that 'feature' which I don't believe - surely every oven makes a sound to let you know your food is finished. Eg if cooking a cake and your at the other end of the house, surely you would usually hear the oven timer finish...?
Gday. We have a westinghouse oven, not the same as yours though. We can choose what type of timer we can put on. One that beeps, one that turns the oven off and some other count down one. I only use the beeping one. Do you have a manual for your oven at all, I suppose if you did you woud look it up... hmmm. Good luck trying to find your answer.
