May 23, 2013 7:43 pmSign In51 members logged in
Building Forum » Building, Renovation & Maintenance » Kitchen Corner
Anyone with Franke Undermount Sinks?
New Topic Post Reply  Page 1 of 1
 [ 9 posts ]
Pink Tulips
 Post subject: Anyone with Franke Undermount Sinks?
PostPosted: Mar 02, 2012 11:57 am
Junior Member
Junior Member
Keen to hear your views/experiences as am deciding between the Kubus KBX 110-70 and Planar8 PEX 110-72.
Thanks in advance ::smile::
barkly
 Post subject: Re: Anyone with Franke Undermount Sinks?
PostPosted: Mar 02, 2012 2:55 pm
Bronze Member
Bronze Member
I have the Kubus 110 34 - not quite as large as the one you are after.
The Kubus sink bottom is flat - slightly tapering to the outlet, whereas I see the Planar has four surfaces that 'fall' to the outlet. In a large sink I suggest this would drain better, not that the flat surface of the Kubus doesn't, but you can see occasional tea leaves in there that haven't flushed out.
Franke sinks are top sinks and provide an excellent under mount finish but if I had my druthers I think I would now go for a flush mount sink where the edge of your bench surface at the sink would be in no danger of chipping. I have seen some discussions elsewhere in these threads where some have complained about chipped sink edges. Hasn't yet occurred to us but you think about it.
Hope this helps
barkly
Pink Tulips
PostPosted: Mar 02, 2012 3:16 pm
Junior Member
Junior Member
Thanks for your reply barkly.
As a matter of interest, have you found that any difference with features on the kubus such as the 'hygienic integrated waste' and 'bowl insulation'?
barkly
PostPosted: Mar 02, 2012 8:44 pm
Bronze Member
Bronze Member
Sorry, I am not familiar with 'hygienic integrated waste' in respect of our model Franke sink - others may know of it and comment - some additional feature other than the sink outlet I presume. There is spray on insulation around all external surfaces of the sink plus an extra glued on sheet of some form of insulation on the base of the sink. Is effective in noise deadening.
HB_
PostPosted: Mar 03, 2012 4:31 am
Junior Member
Junior Member
We have the Peak series undermounted with Antique brown granite benchtop. Looks fabulous! Very modern and stylish.
Peak more expensive than Planar but if if you go for the single bowl version not too much from memory.
Plus the Peak series comes with a cool integrated knob controlled drain stopper (included in box).
Peak bowl also insulated (has coating on the underside of the bowl)
Still being installed so can't comment on use.
Pink Tulips
PostPosted: Mar 06, 2012 2:14 pm
Junior Member
Junior Member
The Peak is really gorgeous sink! Did you go for the single bowl option too?
Pink Tulips
PostPosted: Mar 06, 2012 2:15 pm
Junior Member
Junior Member
Effective noise deadening sounds good ... especially since my kitchen is open and next to the living area.
HB_
PostPosted: Mar 08, 2012 6:00 am
Junior Member
Junior Member
Yes, got the same bowl size as you are looking at PKX 110-70
http://www.franke.com/kitchensystems/au ... etail.html
Rationale is that most of our dishes are washed in the dishwasher so a dual bowl is not so necessary. The large size will be great for the pots and pans. Also less likely to chip the sides of the stone as common in small undermount sinks. We do however have a second smaller sink in the island bench.
The Peak bowl is not as deep as the Planar8 - 180mm vs 200 mm (plus the thickness of your bench as it is undermount).
From memory the Planar is not insulated (coated under the basin) but the Peak is.
On RRP, just checked and it is $470 more though.
Whats the difference between Planar8 and Planar?
The double bowl Peak was astronomically expensive.
Pink Tulips
PostPosted: Mar 08, 2012 2:29 pm
Junior Member
Junior Member
We got down to the planar8 ($1029) and kubus large bowl ($1099) as that was pretty much the max we wanted to spend!
As for the double bowl vs single bowl conundrum, your rational is exactly what we thought ie large size makes it easier for oven trays/large pots/pans & less likely to chip... but then "everyone" has been talking us out of it with advice such as a 2 bowl option is better if we were to wash hands etc....
 [ 9 posts ]
Users browsing this forum: Google Adsense [Bot] and 15 guests
Read Article: What You Need to Consider When Buying New Kitchen Cabinets by Kitchen Craftsmen WAWhat You Need to Consider When Buying New Kitchen Cabinets
You'll also need to consider what style kitchen you like. It…
Read Article: 5 Top Tips to Help You Plan Your New Kitchen by Kitchen Craftsmen WA5 Top Tips to Help You Plan Your New Kitchen
Planning a new kitchen can be a surprisingly stressful experience. There…
Read Article: 4 Things to Look For in Your New Fitted Kitchen by Kitchen Craftsmen WA4 Things to Look For in Your New Fitted Kitchen
The kitchen is one of the most important rooms in any…
Read Article: 2nds World is offering a $50 discount to all Homeone Forum members! by 2nds World Online NT2nds World is offering a $50 discount to all Homeone Forum members!
Simply spend $250 or more on Carton Damaged, Factory 2nd, Refurbished…
Read Article: 2nds World Cooking Clearout – Save on Carton Damaged, Factory 2nd & New Run Out Cooking Appliances by 2nds World Online VIC2nds World Cooking Clearout – Save on Carton Damaged, Factory 2nd & New Run Out Cooking Appliances
We've got a 3 day Cooking Clearout running until Sunday with…
Watch Video: FlexiRobes 40 Sec Video by FlexiRobes VICFlexiRobes 40 Sec Video
FlexiRobes was started in 1979 as a home based business and…
Watch Video: Sink and Bathroom Shop - Largest Display Range by Sink and Bathroom Shop QLDSink and Bathroom Shop - Largest Display Range
Sink, Baths, Taps, Mixers, Toilets - All available at the Sink…
Watch Video: All about Glass Splashbacks by Point Cook Glass VICAll about Glass Splashbacks
All your questions about Glass Splashbacks are answered here in this…
