Browse Forums Kitchen Corner 1 Mar 09, 2011 2:11 pm Hi all, hope you are well. Just a quick question to the forum - Have any of you had experience with the Stefani Inline water filter system($99) available from Bunnings. We are thinking of installing this on our cold water line for the mixer tap and would like to get an idea if the quality is good, especially regarding the water flow rate and if it reduces it too much. Im sure their carbon filters work just as good as the others on market and they range from about $30>$60 depending on how fine the filter is. Iv had a look at HiFlow and it seems a little expensive and does a similar job(>$325 from harvey norman) although the build quality of the unit seems superior. Other product in contention is the PSI filters that have been mentioned favourably here($190) - http://www.psifilters.com.au/buy-online/details/30/8/single-undersink/premium-single-undersink/psi-203p-with-pentek-cbc-10-carbon-cartridge.html Thanks in advanced thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16731 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17809 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14541 |
