Overhead cupboard door size in Kitchen – which is better and reason please 😊
1) 900mm cupboard with two 450mm door
2) 700mm cupboard with two 350mm door
Browse Forums Kitchen Corner Re: Overhead cupboard door size in Kitchen – which is better 2Apr 25, 2024 2:34 am That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into it if there is only 1 cabinet. Obviously the larger the door the wider it will open however 450 isn't crazy for an OH. It more comes down to what fits in the space and in an overall bank of cabinets. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Overhead cupboard door size in Kitchen – which is better 3Apr 26, 2024 10:50 am Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra with that 200mm? 4 1800 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7836 Canopy and Undermount are best, and need to be ducted externally. Which one you go with will be largely determined by your design and joinery choices. What you should be… 1 1394 |
