Hi, wondering if anyone knows if the hafele lemans pull out swinging thing
https://www.bunnings.com.au/hafele-450m ... lsrc=aw.ds
Works with bunnings kaboodle blind corner and face
https://www.bunnings.com.au/kaboodle-10 ... lsrc=aw.ds
Browse Forums Kitchen Corner 1 Sep 06, 2022 12:10 am Hi, wondering if anyone knows if the hafele lemans pull out swinging thing https://www.bunnings.com.au/hafele-450m ... lsrc=aw.ds Works with bunnings kaboodle blind corner and face https://www.bunnings.com.au/kaboodle-10 ... lsrc=aw.ds Re: Bunnings kaboodle blind corner with hafele lemans II 2Sep 06, 2022 12:59 am jleang Hi, wondering if anyone knows if the hafele lemans pull out swinging thing https://www.bunnings.com.au/hafele-450m ... lsrc=aw.ds Works with bunnings kaboodle blind corner and face https://www.bunnings.com.au/kaboodle-10 ... lsrc=aw.ds By the look of the picture the door is hinged on the wrong side. The carcass seems to have the hinge holes on the right side. Lemans need to have a centre mullion and be hinged so the door opens back towards the blind corner. Or the door needs to hinge off the blind panel. Otherwise all the dimensions are suitable to fit a Lemans in the kaboodle after you remove the shelf. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 5429 4 15098 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 6489 |
