Browse Forums Kitchen Corner 1 Aug 11, 2022 9:33 pm Hi all My cabinets don't seem to be aligned and my builder is telling me to just paint the inner cabinets black ... I don't want to do that and I think they messed up. For the cabinet makers out there is there anything you'd suggest for me to request as a fix as opposed to painting inner cabinets ? I don't think this job is acceptable. I can see the white inner cabinets through out all my cabinets. It is as if they didn't fit the cabinets correctly Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What's wrong with my cabinets 3Aug 12, 2022 1:20 am I sent you a PM but for others. The drawer should simply be adjusted up so it sits level with the end panel. That way it would cover the white carcass edge. Personally I use a matching abs edging on my carcass so you don't have this issue. It's particularly important on dark or timber kitchens. It adds a tiny amount to the price but makes a difference to the overall look and prevents this issue. If the door and drawer gaps are correct size and properly adjusted even if you use white edging it shouldn't be overly noticeable but a simple matching of the edging will remove any issue. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10342 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40603 2 31637 |
