Browse Forums Kitchen Corner Re: How is a kitchen island PowerPoint installed? 2Jun 02, 2022 5:22 pm Trench in the concrete for conduit - cables through conduit. Well, it was the default we got with our deign, walking through the build last week felt ok, based on drawings on the floor, it is basically a metre, which is quite a big… 3 834 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16262 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 7233 |
