Browse Forums Kitchen Corner 1 Aug 08, 2021 10:35 am Hello could anyone please help me with views on the attached kitchen layout, The main back wall bench is about 4m with an option to continue it down into wip which is ~1.2x2.2m Or towards a dining space on the oven tower end which is ~3x3m. The two areas I am reconsidering are walk in pantry layout and spacing out the appliances on main bench by- a. relocating oven tower near fridge (in this case not sure what to do with the space which will remain behind it b. move the sink down into wip by removing the wall in between, continuing the same bench to the end of that wall and placing a long pantry shelf in space behind it on opposite side( in wip) fyi. The current wip does consider a sliding cavity door. Thanks in advance for your help and views Re: Kitchen help 3Sep 13, 2021 11:02 pm The bench with all the appliances on it seems quite crowded. Would you consider moving the sink to the island? If there is room you could increase the depth of the island, and have some shallow cupboards opening to the other side, that would accommodate a sink better than a narrow island. If you’d prefer the sink in line with the cooktop, I prefer option 2 for less wasted space and allowing you to keep dirty dishes out of sight a little more Re: Kitchen help 5Dec 26, 2022 7:51 pm I'm having the same dilemma in designing our kitchen. Have you since built this kitchen? If so, did you go with option 2 and how is it? Thanks, You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 17511 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 7116 2 5566 |
