Browse Forums Kitchen Corner Re: Kitchen island 2May 03, 2021 8:16 pm It can't be changed now so will have to be painted or you could laminate it but probably just as easy to paint. Really the underside of the overhang should be stone just like the sides of the waterfalls, or at least that is how my stonemason does them. If using stone on the underside was going to end up pushing into using another slab then I'd give the client the option of either getting another slab, using standard white stone or a white melamine. Obviously the cost would vary between the 3 options. If you are going to have exposed substrate then yes, I would have used white melamine. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Well, it was the default we got with our deign, walking through the build last week felt ok, based on drawings on the floor, it is basically a metre, which is quite a big… 3 847 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 7237 2 6345 |
