Browse Forums Kitchen Corner Re: Gas Hotplate cutout on Stone Benchtop 2Nov 16, 2020 4:43 pm They vary depending on the cooktop. You'll be in the ball park but it's not uncommon for them to vary by enough to cause difficulty. Best thing is to try and look up the model number of the existing cooktop and get the cutout dimensions off their website, then try and find one with the same cutout. You can get it cut bigger if you are happy to pay but obviously smaller is not the best. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Gas Hotplate cutout on Stone Benchtop 3Nov 16, 2020 7:25 pm chippy They vary depending on the cooktop. You'll be in the ball park but it's not uncommon for them to vary by enough to cause difficulty. Best thing is to try and look up the model number of the existing cooktop and get the cutout dimensions off their website, then try and find one with the same cutout. You can get it cut bigger if you are happy to pay but obviously smaller is not the best. Thanks for that chippy. I guessed that may be the case. Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 13337 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7436 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 6300 |
