Browse Forums Kitchen Corner 1 Sep 10, 2020 1:02 am Hi all, I will be installing stone benchtop after handover. I do want to have shadowline feature on the cabinetry - is this something I have to work with my builder to ensure they add shadowline below the the laminate? or can i do this after handover with the installation of the stone benchtop? thank you so much!! Re: Install stone benchtop afterhandover - shadowline 2Sep 10, 2020 1:11 am elloelloelloqwer ...is this something I have to work with my builder to ensure they add shadowline below the the laminate? Do you mean a laminate benchtop that you are having temporarily fitted? Re: Install stone benchtop afterhandover - shadowline 4Sep 10, 2020 12:32 pm elloelloelloqwer yes sir Re: Install stone benchtop afterhandover - shadowline 5Sep 10, 2020 1:41 pm arcadelt elloelloelloqwer yes sir OK. The shadowline is actually created by the cabinetry under the bench top, so your builder would need to arrange for his cabinet maker to make it that way with the laminate on top. The supplier of the stone bench top would then just remove the laminate top and install the stone one. This is very easy if the laminate top and stone are exactly the same thickness and profile, but more difficult if different. Of course, you could save a few dollars by not putting any bench top on, as removing that would just be a waste. All this is best if you bench top supplier and the builders cabinet makers can work together on the design. Thank you so much for your detailed response!! I really appreciate your help on this! I will ask if they can not put any benchtop on. Will a benchtop be legally required for handover? Hopefully not, as I believe my builder might say something with the likes of that.. Re: Install stone benchtop afterhandover - shadowline 7Sep 12, 2020 7:48 am We have a stone island bench with waterfall ends but not happy with the join. Would it be possible to change the stone over the island without having to redo everything including the waterfall ends? Re: Install stone benchtop afterhandover - shadowline 8Sep 12, 2020 7:52 am Housetohome We have a stone island bench with waterfall ends but not happy with the join. Would it be possible to change the stone over the island without having to redo everything including the waterfall ends? Re: Install stone benchtop afterhandover - shadowline 9Sep 12, 2020 7:55 am arcadelt Housetohome We have a stone island bench with waterfall ends but not happy with the join. Would it be possible to change the stone over the island without having to redo everything including the waterfall ends? Thanks 😊 will do. Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 13309 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8943 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7405 |
