Browse Forums Kitchen Corner Re: Help! How would you structure the utilities in THIS kitc 4Oct 01, 2021 12:09 pm Hi @Molo Audace Your biggest constraint is going to be fitting everything into the space you have available. Whilst what Alex has said is great in a commercial kitchen where they have stations for everything a domestic kitchen has to blend practicalities of being a working kitchen along with limited space available and keeping the aesthetic. Once you move the sink off the island (which I always try to do as well) you are going to start to get pretty tight around that back wall. A couple of questions. What sort of ovens do you want wall or underbench? Is 900mm wide enough for your fridge space? What is the distance from the wine cabinet to the back wall, in other words the bench length down that wall. I can only see 2 possible layouts for you based on your responses I'll try and run you through them. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 7096 8 4879 Shade the brick with large eves. Since going to minimum of 600mm eaves on my build, I've noticed much improved cooling off the house after hot summer days. Can see the… 1 4721 |
