Browse Forums Kitchen Corner Re: Solid timber kitchen cabinets with plywood carcasses? 5Oct 19, 2008 10:36 pm Thanks again Earl.
We're going for flat panel, wenge for the island cabinetry - so pretty dark! The tall kitchen cabinetry will be something lighter in 2pac poly (satin finish)...the island benchtop will be a combination of stainless steel and probably caesarstone...and the floor will be tiled in a light coloured, 'concrete-look' tile... Hopefully it will all work out how we want it to! We have kinda 'borrowed' the idea from a Poliform kitchen we really liked the look of...so fingers crossed!! Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16763 Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4329 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10692 |
