Browse Forums Finishing Touch 1 Aug 13, 2020 1:41 pm Re: Paint cracking advice 2Sep 20, 2020 9:30 pm Cracked paint can have a number of causes. For example, mud cracks usually indicate that too many layers of paint were applied on the surface or the wall was dirty. Hairline cracks, on the other hand, are indicative that the paint was cheap and had low adhesion or was spread too thinly 1 6812 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 21581 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7515 |
