Browse Forums Finishing Touch 1 Dec 11, 2016 12:49 pm Hi all, First of all how i upload a photo i have snipped from a website? anyways i'm trying to figure out which sander is required for this job i'm going to be needing it to remove glue from a VJ ceiling as there was wall paper originally there. https://www.realestate.com.au/property/ ... y-qld-4051 there are photos in the link. Cheers, Elives If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8877 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17841 |
