Browse Forums Finishing Touch 1 Sep 15, 2015 10:17 am Getting cracks in wooden furniture are very common especially with old wooden furniture. If you notice a crack in your precious wooden furniture and would like to fix the crack, do not fret. You can do the following:- • For very small holes in your wooden furniture, you can use a wood coloured putty stick. To apply the putty stick, spread it across the hole and smoothen the surface. Let the putty dry for at least a week if you wish to refinish the wood afterwards. • For larger cracks, use a wood filler and water putty instead. Before applying these products, make sure to clean the crack with the tip of a craft knife. Then use the same knife to press the plastic firmly into the crack. Did you recently have a cracked wooden furniture that you have repaired? How did you repair it? Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4955 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 9065 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9243 |
