Browse Forums Finishing Touch Re: Gloss, Semi-gloss, Low Sheen??? 4Dec 02, 2011 7:19 pm polarbear66 Can someone please tell me what is the best type of paint to use for their external / internal painting? I am planning to use Dulux. I need to let the builders know our preferences ASAP. I have finally sorted out the colours, now just need to decide on the finish. Internal Walls Dulux Wash & Wear Low Sheen - the only one I'm sure about lol! Ceilings Dulux.....???(just want white) Pure White, not tints no shades Doors Dukux Enamal?? Would you use a gloss product? YES Skirtings / windows Dulux Enamal??? YES External Gutters Dukux Weathershield Gloss, Semi-gloss, low sheen??? Full gloss Fascia Dulux Weathershield Low Sheen Full gloss Eaves Weathershield Low Sheen YES What do people generally use?? I always suggest any exterior work to be done in a weather shield full gloss. Interiors full gloss on all timber trims and doors and semi gloss on the walls. In my house I have even used semi gloss on the ceilings. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 26317 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 18026 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 14602 |
