Browse Forums Ideas Box Re: Strange word block? 2Aug 18, 2013 11:08 am hi itzeddie Homeone has an issue with words like that because often someone who is a disgruntled customer of a business will join the forum to vent/let off steam. There are quite a few words that are blocked like this one. Ly ing is another. So in order to cut down on the amount of work for we, volunteers these words are banned. It can be a nuisance as there are perfectly valid reasons sometimes for wanting to use them and it frustrates me as well sometimes but it helps make the volunteer support members work easier in the long run and sometimes will be enough to make someone stop and think before they post something that is defaming and which could lead to them being taken to court. kexkez Forum Support Team Member Re: Strange word block? 3Aug 18, 2013 2:05 pm kexkez hi itzeddie Homeone has an issue with words like that because often someone who is a disgruntled customer of a business will join the forum to vent/let off steam. There are quite a few words that are blocked like this one. Ly ing is another. So in order to cut down on the amount of work for we, volunteers these words are banned. It can be a nuisance as there are perfectly valid reasons sometimes for wanting to use them and it frustrates me as well sometimes but it helps make the volunteer support members work easier in the long run and sometimes will be enough to make someone stop and think before they post something that is defaming and which could lead to them being taken to court. kexkez Forum Support Team Member Makes sense, thought it would be something along those lines, thanks for the quick reply Re: Strange word block? 4Aug 18, 2013 4:18 pm D odgy is another one. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Strange word block? 5Oct 05, 2017 3:31 pm Deemaree D odgy is another one. I came into this section of the forum to ask why that was blocked. As it's a very common word that is used in Aussie speech far more than in a truly negative tone. But I guess if it makes it easier, just means you use a synonym. That can have a stronger connotation than the 'original' slang. Re: Strange word block? 6Oct 05, 2017 7:51 pm In complete agreement with you rum_home All members are highly valued and the contributions are always overwhelming. That said, infrequently there's sometimes a small handful of individual's that disregard the Terms of Use, and join communities (like this one) for the sole intent of [further] damaging the reputation of particular builders (or companies) in question. Granted, sometimes individual's have their strong case, but tagging a company with this term is highly damaging. Ultimately, it was decided to censor the word - some years back - much to the frustration of yourself and others who do the right thing! Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 13366 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11031 6 11428 |
