Hello all.
I'm wondering if there's a way to save and/or bookmark individual posts ?
Browse Forums Ideas Box Re: Saving / Bookmarking Posts ? 2Jul 28, 2022 4:11 pm Click the the three dots in the lower right hand corner of a post and select 'Copy Link to Post'. You can then bookmark direct to that post. Re: Saving / Bookmarking Posts ? 3Jul 28, 2022 4:42 pm orionnebula Click the the three dots ... Thanks, but I was not looking for direct links to posts, but a mechanism, where we could "bookmark" or "save" posts to our Forum profiles. Currently, we can 'Like' posts, and go to our profiles to see the 'saved' posts that we liked, but I was wondering if there was a way to actually "bookmark" posts and/or threads, for posterity's sake Re: Saving / Bookmarking Posts ? 4Jul 28, 2022 4:53 pm Not per se - but using the direct link will allow you to save an actual bookmark to your browser which you could save/sort into a folder etc. brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7623 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7079 |
