Browse Forums Real Estate 1 Jun 11, 2014 12:06 pm Hi just starting to look for block of land in Point Cook or Truganina? We looking for land with min 17M frontage and min 600M2. Any one can post some price indication? Any cost savings if you purchase before land release from developer? No experience with developers before? Can you negotiate with them after block has been released to be subject on soil test and your house design approval by their board? Any advise will be appreciated Thank you Re: Buying Land in Truganina & Point Cook area price per M2? 2Aug 06, 2014 10:16 am soil test yes its possible, house design approval, no. couple of things to consider first is that by the time you get to the builder submitting your house design to the design panel for approval, you are invested. You've done your colour selections, house adjustments (moving walls adding alfresco's etc) generally you should already have finance approved etc. if you pull out at that stage you generally will lose your deposit I'm pretty sure. As to soil tests. Ill save you the hassle - Tuganina is mostly H2 with some sites on H1 and some on P at either side of the bell curve. Most of the west is poor to average soil to build on. Expect this, and forget about the hassle of getting developer standard contracts changed. As to size and frontages - Most larger blocks with those types of frontages out in those new estates are odly shaped, so you might get +17 meters at the front, but it tapers back out the back making it hard to fit some bigger houses on the land. Have you considdered buying two blocks side by side? I know the expense is there, but it would give you a much more uniform solution. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17631 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6879 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5054 |
