Browse Forums Real Estate 1 May 11, 2013 6:39 pm hi everyone Need some advice please... bought a brand new constructed townhouse, it is completed, only touch ups required. Real estate agent, bank and conveyancer has advised that plan of subdivision has been applied but not approved yet, and title not registered. We settle in June. Just wondering what happens if builder/vendor cannot get subdivision approved, conveyancer has stated that we can walk away from purchase if subdivision is not approved, is this correct? And has anyone else out there ever experienced this sort of purchase before? Does the subdivision generally come in on time? I believe it can take up to 18 months! Regards Wizard Re: Bought newly constructed townhouse but not subdivided ye 2May 11, 2013 6:54 pm I would assume that the contract for sale requires a property on individual title. If the vendor can't deliver that yes you should be able to walk away. If you want to understand the process so you can check what the issues are there is a guide here http://www.anewhouse.com.au/?p=4778 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Bought newly constructed townhouse but not subdivided ye 3May 11, 2013 7:13 pm Hi bashworth Thanks for the prompt reply. Yes, the contract and the bank will require a title before we can settle, no title no settlement. Hence want to know what will happen if title does not get registered in time. Apparently vendor legally has up to 18 months for this occur. Has anyone else dealt with such a transaction before? Regards Wizard The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16262 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5054 My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 1483 |
