Browse Forums Real Estate Re: good value????????? 2Jun 22, 2011 2:26 pm I have no idea where Mont Perry is. But 1/4 acre is 1000sqm. That should be plenty big enough for any house. Most city estates are releasing blocks at 400sqm, so less than half that! If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8917 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 28054 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 10176 |
