Browse Forums General Discussion Re: Reverse Brick Veneer 2Mar 29, 2017 4:54 pm I can't answer your question re costs in Adelaide as I built as an owner builder in rural South Australia. My house is solar passive with double brick in living areas which are north facing and insulated timber frames on other elevations and also for internal walls in the southern side of the house. My OB build thread is at viewtopic.php?f=38&t=71081 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4602 5 10903 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7743 |
