Browse Forums General Discussion 1 Jun 07, 2008 7:41 pm I've seen some lovely door handles at Bunnings and they're only between $5 and $10 each. (satin chrome curved bar type things)
If I bought them, how much would someone (just a general handyman, or a cabinet maker or who would I get to do this?) charge to fit them and remove the existing (small white button knob) handles? How the hell did I become a senior member!? I know nothing! Re: How much to replace kitchen cupboard door handles? 2Jun 07, 2008 7:56 pm Do you mean you bought ones that have two holes to screw in, and only have one hole in the cupboard already?
Mmmm I'd have a go myself - not that hard. screw the first one in then mark on the cupboard where the second one sits then drill hole and screw second screw in. Paula Re: How much to replace kitchen cupboard door handles? 3Jun 07, 2008 10:52 pm grace_slick I've seen some lovely door handles at Bunnings and they're only between $5 and $10 each. (satin chrome curved bar type things) If I bought them, how much would someone (just a general handyman, or a cabinet maker or who would I get to do this?) charge to fit them and remove the existing (small white button knob) handles? If you are going from a handle that has one fixing screw to two, the only problem you will have is with draw fronts, as the handles wont be in the centre if you use one existing hole Bunnings have a markup of about 500% on some of their handles And if you need longer screws than supplied, you will have to buy them separately A handy man or cabinetmaker should be able to fit your handles for you I carry a fixing box with all the available screws required Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: How much to replace kitchen cupboard door handles? 4Jun 08, 2008 8:59 am Kevin Brown If you are going from a handle that has one fixing screw to two, the only problem you will have is with draw fronts, as the handles wont be in the centre if you use one existing hole Oh yes there is that problen as well. Paula Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 3049 3 4249 |
