Browse Forums General Discussion 1 May 15, 2008 5:01 pm Hi folks I'm new around here.
The last few days I've been installing the down pipes on a prefabricated house, these pipes join together underneath the house and finish into one single pipe which leads to a drain. My question is: How much fall should be on the pipes? I remember when guttering I only had something like 10-15mm for every 5m of gutter. So with the plumbing under the house I did the same. Quality Controle comes over and says he wants 300mm fall. I remember when doing airial downpipes (which run horizontaly) I didn't have fall at all (they were level and the water worked it's way out eventually), I've even done this with gutters on awnings too. What is the proper procedure? Thanks for your time in advance. There will be many more questions where this came from. teach me 4 6163 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 6037 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11321 |
