Browse Forums General Discussion 1 Aug 10, 2006 11:45 am Hi,
I am in the process of organising to have a colourbond garage/shed built in my backyard. The shed is 3.9m x 6.2m and will not have a roller door. It will sit on a 100mm reinforced slab. A couple of questions: 1. I have been told that it can only be built 15cm from the fence (boundary) or 1metre - nothing in between. I have the fence posts on my side so is that 15cm from the posts or 15 cm from the palings? 2. My block slants upwards from the front to the back. Does anyone know if it is acceptable to have the front of the slab sit out of the ground and the back sit flush with the ground in the rear. The property is situated in the Boroondara area in Melbourne. Any asistance provided would be greatly appreciated. Cheers, Theborg Re: Rules for building a Garage/Shed 2Aug 10, 2006 2:54 pm Quote: I have been told that it can only be built 15cm from the fence (boundary) or 1metre - nothing in between. I have the fence posts on my side so is that 15cm from the posts or 15 cm from the palings? Quote: 2. My block slants upwards from the front to the back. Does anyone know if it is acceptable to have the front of the slab sit out of the ground and the back sit flush with the ground in the rear Hope that helps.. Re: Rules for building a Garage/Shed 3Aug 10, 2006 3:25 pm Thanks Builda.
The slab sits on concrete footings which are 300x300x300. The footings will sit in the ground and the good news is I (with the help of family members) do not have to dig and shift as much soil. Very much appreciate your assistance. Cheers, Theborg Re: Rules for building a Garage/Shed 4Sep 11, 2006 11:03 am builda Quote: I have been told that it can only be built 15cm from the fence (boundary) or 1metre - nothing in between. I have the fence posts on my side so is that 15cm from the posts or 15 cm from the palings? Careful there - a fence does not equal a boundary. If your neighbour surveys his land and finds that your garage is on his land, guess what? He's within his rights to claim it back! And I know of lots of *** fences that cross their boundary. I'd get the survey done - $500 well spent. DIY, Home Maintenance & Repair Turning this into my DIY shed makeover. I had a brickie fix the back wall up and it's rock solid now. I'm into ripping down the inside ceiling that was installed and… 1 12434 1 2061 "is it exempt or do I need to get permission from council" Call your Council and ask them 1 2171 |
