Browse Forums General Discussion 1 Aug 09, 2005 3:25 pm Hello everyone, I have a question regarding roof restoration. We have a two story concrete tile roof and have had a couple of qoutes to restore the roof. Now my problem is the qoutes range from $3050 upto $6740. Do you really think there would by much difference between companies to warrant such differences in qoutes. Is there anything I should be wary of?Also do I have to have Safety rail put up around the roof while they are carrying out the work?
Any help would be much appreciated. Thanks. Roof restoration 2Aug 11, 2005 8:35 am A safety rail will need to be installed & this should form part of the quote.
If the firms are quoting on exactly the same work (& allowing for the same items such as site clean up etc then the prices should be similar) when you receive a quote it ashould be detailed and not just "replacement of roof tiles" or the like. Larger firms may have bigger overheads ( & better buying power) but their prices should be competitive across the board. With such variations in price I would be looking at obtaining further quotes before making a decision. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3519 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11812 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28621 |
