Browse Forums General Discussion 1 Jun 07, 2007 1:45 pm hello,
Wondering if any one can advise on the rules relating to the use of 2nd hand timber for sub floor frame supported by concrete stumps. I am required to use: 95 x 45 hyspan lvl for the joists, and 140 x 45 hyspan lvl for the bearers. I realise it may not be that easy to find 2nd hand lvl, but an equivalent could be used. How would I determine this? Any info greatly appreciated. Thanks Greg Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29570 Regardless of the trees route undermining your footings and slab or not. Trees need to be away from the buildings as per the BCA requirements below otherwise the design… 1 663 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4892 |
