Browse Forums General Discussion 1 May 08, 2024 2:12 pm Our timber frame is sitting on the slab, and the brickwork is sitting on the little concrete shelf made for the bricks on the edge of the slab. I am wondering if the overhang on these windows (the bottom of the window frame is overhanging the slab by quite a bit) is ok? Thanks, Fiona Re: Slab overhang (by window frame) 2May 08, 2024 2:14 pm FionaSmith Our timber frame is sitting on the slab, and the brickwork is sitting on the little concrete shelf made for the bricks on the edge of the slab. I am wondering if the overhang on these windows (the bottom of the window frame is overhanging the slab by quite a bit) is ok? Thanks, Fiona Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab overhang (by window frame) 3May 08, 2024 8:11 pm Can you post 2 photos of inside showing window reveal against timber frame Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Slab overhang (by window frame) 4May 08, 2024 8:45 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the best I have, as it is plastered internally now. I should add there is a steel post in the corner of the room between the window and the glass sliding door, and steel beams in the roof, so I presume the windows are non-load bearing; not sure if that makes any difference? In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 8015 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 4064 This is 100% true. You can not hang anything on steel frames. very frustrating 8 9917 |
