Browse Forums General Discussion 1 May 02, 2024 9:50 pm Any tilers here that can answer this question. Today we screeded our balcony. How long before I can assess if it is a success or a failure. it looks a bit flaky and like it might crumble if I were to put too much pressure on it (I am worried that we did not use enough water in the mix). Re: Screed First Timer 2May 03, 2024 4:49 am renovator_me Any tilers here that can answer this question. Today we screeded our balcony. How long before I can assess if it is a success or a failure. it looks a bit flaky and like it might crumble if I were to put too much pressure on it (I am worried that we did not use enough water in the mix). Not a tiler here but a builder. We screed our entire ground floors as a matter of practice and just finished one yesterday, so I have a little experience. Screed by it's nature can be a bit flaky and at this time of year as the weather is cooling, it is taking a good 4-5 days to dry. After a couple of days it should be firming up enough to walk on gently. I would say that if it hasn't gone hard in 48 hours you have failed. Let me know if you want a photo of what it should look like cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Screed First Timer 3May 03, 2024 10:38 am thanks Simeon, I will check it again tomorrow afternoon (which will be 48hrs). Our mixture was 2 buckets of sand, half bucket cement and 3L of water. Any thoughts on these ratios? Re: Screed First Timer 4May 03, 2024 12:50 pm renovator_me thanks Simeon, I will check it again tomorrow afternoon (which will be 48hrs). Our mixture was 2 buckets of sand, half bucket cement and 3L of water. Any thoughts on these ratios? Your sand and cement ratio is fine. With the water it is hard to be precise as it depends on the water content of the sand. This is generally done by eye. So you are looking for a slightly damp powdery mixture, not too wet and not too dry, but generally more like a damp sand that can be moulded into a shape....if that makes sense Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Screed First Timer 5May 04, 2024 2:32 pm It seems like it has hardened suitably within 24 hours Now it is time to tackle the other balcony. Re: Screed First Timer 6May 16, 2024 3:56 am renovator_me It seems like it has hardened suitably within 24 hours Now it is time to tackle the other balcony. Keen for an update. How did you get on with your 2nd balcony? Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Hi all, We're curring working on our outdoor and have some questions in relation to screed. I've tried to find information online, without success. Apologies for the… 0 3472 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5384 Levelling compound also works well for this, you can feather it and it doesn’t self level at this low thickness , you can build up in layers if need be. 2 7440 |
