Browse Forums General Discussion Re: Drainage 2Mar 28, 2024 9:59 pm You can use a better version of a French drain called a cut off drain along your fence line and run a plastic membrane over the ground between the house and the drain pipe and will create good drainage. Re: Drainage 3Mar 29, 2024 7:42 am GroundZero "use a better version of a French drain called a cut off drain" That's the one, it's similar just dig the trench and the line the trench with some geotextile fabric and layer with some coarse aggregate. Place a perforated pipe on top of the aggregate. Fill up the trench with more aggregate and make sure it is compact (Careful not to crush the pipe!) HTH Regards -= Are you still using a notebook or spreadsheet to keep track of your customers and appointments? You need Simple Time Planner - Free Appointment Software =- Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12361 2 5908 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3169 |
